HELP Bluetti AC300+B300K problem UPS mode
Hello, I recently purchased a Bluetti AC300+B300K station. The station works in UPS mode to power my computer during power outages. When the power goes out and the station turns on, the computer reboots. Please tell me, do I need to change any settings? Or turn something on? The station is in standard UPS mode.
When I manually disconnect the station from the power outlet, the computer continues to operate. I believe that if I do not touch the station for a certain period of time, it goes into sleep mode.
This is because when the power is turned off, a switching sound can be heard from the station.
Hello, if you turn on UPS mode, the device will not shut down automatically. As for the computer restart issue, you can check if there are any settings on your computer that can be modified.
The problem has been solved. I had to disable the self-adaptive charging mode in the settings. After disabling this setting, the computer does not restart during power outages. Thank you.
