Hi all, a few weeks ago, we got hit with a bunch of rain when I wasn’t expecting it and my AC50 was sitting where it took on some water. I let it dry for a week then tried to turn it on. The power light flickered then it shut off. I opened it up, disconnected and reconnected everything and tried it - boom, it was good! I also plugged it in and verified it was charging and it was putting out charge to my phone. So I put it all back together and it gives the E05 error (unit is too cold). It’s not cold so there’s a ghost in the machine. No idea what changed when I put it all together again as nothing is unplugged or getting pinched. I just took it apart again but only E05.
Any suggestions for this issue? I hate to give this thing up as I use it frequently and the batteries all seem to be in great working order. One of the circuit boards need replaced, maybe?
@Scoob If you leave it under the normal temperature condition for a long time and restart AC50 and it didn’t solve the problem, I think the AC50 needs to be repaired by technician.
Ok all, I finally found the problem. Somewhere along the line the NTC Bat wire got pinched in the chassis to the point that it cut the wire. I finally found it tonight so I know what the problem is - but fixing it may prove difficult since the wire runs under the battery pack so I have to remove everything to get to it to solder in a new wire. But at least I know that the rain didn’t kill it.
So it looks like I fixed it with a $5 thermistor off Amazon, no thanks to the support team. The connector was a slightly bigger size that I cut down to fit with a razor blade. The unit is working again, charging on DC and AC. I assume charging will also be functional when I get low enough to connect to the solar panel.
I’ll note that the batteries have held their charge for the last 11 months without any obvious degradation. I’m very happy I got the unit functional again.
