I have encountered a problem. The generator started NOT CHARGING last night. Not sure why. So this is the situation. I bring down to 1 AMP. Still not charging. The GRID icon on the app is green so it receives input. Actually I can read the input which is 242.5V and 50.01HZ, the only fluctuation I see on the bluetti screen are the last numbers 5 and 1 sometimes goes to a 4 and a 2. Therefore the current seams to be extremely clean. I also updated the AC500 firmware to v9041.12. I have not updated the batteries yet (should I do that?). On advanced settings I tried to enable the Grid self adaptation but it doesn’t let me do it (and yes I tried that with Bluetooth connection). Running out of ideas here… it seams there is a safety mechanism on the bluetti that is blocked and doesn’t want to accept any AC input from my generator. The generator works well if I plug it to a power tool or anything else so I am deducing it it a problem of the AC500 that for some reason is not happy…
Yes, so I have been using this generator to charge my bluetti system for more than 1 year. Maybe once a month (the rest with solar). It is inverted. Pure sinowave
When charging with an unstable generator or grid power, or if consumption power exceeds charging power, enable this mode in the app. The Apex 300 automatically adjusts to handle power fluctuations, protecting the unit and connected devices from potential issues due to variations in power quality
So this is interesting. Yes I tried to switch on that mode. It doesn’t let me. It is my understanding you need to be connected via bluetooth (not via cloud or wifi) in order to actually put the AC500 in 8. Grid Self-Adaption Mode. So I did that as well but it doesn’t even allow me to enable it… the command remains in the grey mode.
