Just ordered an AC2A today with a birthday gift card that was close to expiring. So I used all the codes and the gift card (all in for $154), and decided to download the manual and look at it a bit. I saw this early on. What?? The unit takes 12-28 volts of solar input like pretty much all the other small Bluettis, but here it says this (item 2, under warnings, attached): “Do not use solar panels with open circuit voltage higher than 60V.”
Was this copied and pasted from another unit? I’m pretty sure using a solar panel with (say) 50V OCV with this unit would either refuse to work (if you are lucky) or cause the poor device to fry (if you are not).
Am I missing something?
