Follow-up — Bluetti Elite 30 V2 with High Standby Power Consumption (Final Results)
Hello everyone,
This post is a follow-up to my original thread, “Bluetti Elite 30 V2 with High Standby Power Consumption.” Since I can no longer edit that post to add the final test results or correct a few minor mistakes, I created this new one to provide the complete and updated findings.
After conducting additional tests and refining the methodology, I’m now sharing the final results for my Bluetti Elite 30 V2 — with a focus on real-world power consumption, efficiency, and detailed measurement procedures.
Below you’ll find all final data collected from my Bluetti Elite 30 V2.
:clipboard: Device Specifications & Acronyms
Bluetti Specification
Model Elite 30 V2 (EU – 230 V)
Battery capacity 288 Wh LiFePO₄
Inverter 600 W (Pure Sine Wave)
AC Input 380 W Max
AC Input (with Bypass) 980 W Max
Warranty 5 Years
Acronym Meaning
W Watt
Wh Watt Hour
η Eta (Inverter efficiency)
AC AC (Alternating Current)
- The flow of electric charge that periodically reverses direction
DC DC (Direct Current)
- The flow of electric charge in one direction only
h Hour
SoC State of Charge
DoD Depth of Discharge
Δ Delta (Change)
Approximately Proportional
N/A Not Applicable
:electric_plug: Output Measurements
Important
  • Device Rated Power: Manufacturer’s specified maximum power consumption.
  • Measured Load (actual): Independently measured real load using external instrumentation. The ± symbol indicates the measurement tolerance.
  • Power Station Reading: Output reported by the Bluetti Elite 30 V2’s internal sensors (accuracy ± 1% of reading).
  • Measurement Equipment:
    • Anker Prime Powerbank: Internal sensors (accuracy ± 2%) Source: Based on testing reported by Battery Skills.
    • Eastron: Model SDM230-Wi-Fi (accuracy ± 1%) MID Certificate number 0120/SGS0206 Source: Manufacturer documentation.
Output Type Connected Device Device Rated Power (W) Measured Load (W) Power Station Reading (W)
AC Inverter (230 V / 600 W) Bestron Fan (model ASV45Z) 45 ± 41 ± 41
DC Output (USB-A 15 W) Anker Prime Powerbank 27K (model B1340) 15 ± 11.7 ± 12
DC Output (USB-C 100 W) Anker Prime Powerbank 27K (model B1340) 100 ± 98 ± 94
DC Output (USB-C 140 W) Anker Prime Powerbank 27K (model B1340) 140 ± 138 ± 136
DC Output (DC5521 Port, 12 V / 10 A) N/A N/A N/A N/A
DC Output (Cigarette Lighter Port, 12 V / 10 A) N/A N/A N/A N/A
Note
The table above compares measured vs. rated output power to validate the accuracy of the unit’s internal sensors.
:test_tube: Testing
Note
  • The ± symbol indicates the measurement tolerance of the equipment used.
  • Grid/Solar Plug-in and Grid/Solar Not-Plug-in results show negligible variance (<0.5%).
  • Separate tests were conducted for Base Standby + Bluetooth and Base Standby + Wi-Fi, with results falling within a ± 1 W margin. As a result, these modes are grouped together in the standby results table.
  • Total Load represents the combined output power from both DC Output and AC Inverter sources.
  • Average Power is the estimated average hourly power consumption, calculated from the change in State of Charge over time (Δ SoC).
  • Conversion Losses represent the difference between total energy used (Energy used) and the calculated standby-adjusted output energy (Output Total).
  • The Depth of Discharge (DoD) and inverter efficiency (η) values can be found in the Bluetti Elite 30 V2 manual under FAQs – Q5: “How to calculate the operation time?”
Calculation methods (Important)
  • Energy used (Wh):
    Energy used = Battery capacity (Wh) × Δ SoC (as decimal)
    Example: If Δ SoC = 47%, then the decimal value is 0.47.
  • Average Power (W):
    Average Power = Energy used (Wh) / Duration (h)
  • Output Total (Wh):
    Output Total = (Total Load (W) + Standby Power for Mode (W)) × Duration (h)
  • Conversion Losses (Wh):
    Conversion Loss = Energy used (Wh) - Output Total (Wh)
  • Conversion Losses Percentage (%):
    Conversion Loss (%) = (Conversion Loss (Wh) / Energy used (Wh)) × 100
  • Operation Time (h):
    Operation Time = (Battery Capacity × DoD × η) / (Load + Self-consumption)
  • Example — Operation Time:
    • Battery capacity: 288 Wh
    • Load: 40.96 W
    • Self-consumption: 9.84 W
    • Depth of Discharge (DoD): 0.95
    • Inverter efficiency (η): 0.90
    Operation Time = (288 × 0.95 × 0.90) / (40.96 + 9.84) = 246.24 Wh / 50.80 W ≈ 4.85 hours
  • Example — Discharge Test:
    • Energy delivered (Measured): 200 Wh
    • Duration: 4 h 53 m ≈ 4.883 h
    Average Power = 200 Wh / 4.883 h ≈ 40.96 W
  • Charge Efficiency (%):
    Charge efficiency = Battery capacity (Wh) / Consumed Energy (Wh)
  • Discharge Efficiency (%):
    Discharge efficiency = Delivered Energy (Wh) / Battery capacity (Wh)
  • Total Round-trip Efficiency (%):
    Round-trip efficiency = Delivered Energy (Wh) / Consumed Energy (Wh)
  • Total System Loss (%):
    Total system loss = 100% - Round-trip efficiency (%)
Mode Power (W) Relative to Base Standby (%)
Base Standby 9.12 0%
Base Standby
  + Bluetooth/Wi-Fi
9.84 7.89%
Base Standby
  + Bluetooth/Wi-Fi
  + DC Output
9.36 2.63%
Base Standby
  + Bluetooth/Wi-Fi
  + AC Inverter
10.08 10.53%
Base Standby
  + Bluetooth/Wi-Fi
  + DC Output
  + AC Inverter
11.28 23.68%
Efficiency Test Results
Test Results Overview
Parameter Discharge Test (100% → 0%) Charge Test (0% → 100%)
Start Time 11:05 16:00
End Time 15:58 17:30
Total Duration 4h 53m 1h 30m
Power / Mode Constant Load (~41 W) Turbo Mode (~380 W)
Total Measured Energy 200 Wh (Delivered) 354 Wh (Consumed)
Note
The unit delivered 200 Wh during the full-discharge test, lower than the rated 288 Wh battery capacity, primarily due to inverter and conversion losses.
Efficiency Summary
AC Input (grid power) Value DC Input (solar power) Value
Charge Efficiency 81.36% Charge Efficiency N/A
Discharge Efficiency 69.44% Discharge Efficiency N/A
Total Round-trip Efficiency 56.50% Total Round-trip Efficiency N/A
Total System Losses 43.50% Total System Losses N/A
Note
The metrics under the DC Input column are marked as Not Applicable (N/A) because the required instrumentation for DC charging efficiency measurements was not available for this test.
Test Matrix (Detailed Measurements)
# Mode DC Load (W) AC Load (W) Total Load (W) Start SoC (%) End SoC (%) Δ SoC (%) Energy used (Wh) Duration (h) Avg. Power (W) Conv. Losses (Wh) Conv. Losses (%) Input Source Charging
01 Base Standby
  + Bluetooth/Wi-Fi
  + DC Output
  + AC Inverter
N/A N/A N/A 100% 53% 47% 135.36 12 11.28 N/A N/A Grid (Plug-in)
Solar (Plug-in)
NO
02 Base Standby
  + Bluetooth/Wi-Fi
  + AC Inverter
N/A N/A N/A 100% 58% 42% 120.96 12 10.08 N/A N/A Grid (Plug-in)
Solar (Plug-in)
NO
03 Base Standby
  + Bluetooth/Wi-Fi
  + DC Output
N/A N/A N/A 100% 61% 39% 112.32 12 9.36 N/A N/A Grid (Plug-in)
Solar (Plug-in)
NO
04 Base Standby
  + Bluetooth/Wi-Fi
N/A N/A N/A 100% 59% 41% 118.08 12 9.84 N/A N/A Grid (Plug-in)
Solar (Plug-in)
NO
05 Base Standby N/A N/A N/A 100% 62% 38% 109.44 12 9.12 N/A N/A Grid (Plug-in)
Solar (Plug-in)
NO
06 Power Station OFF N/A N/A N/A 100% 99.90% 0.10% 0.288 24 0.012 N/A N/A Grid (Not-Plug-in)
Solar (Not-Plug-in)
NO
07 Base Standby
  + Bluetooth/Wi-Fi
  + DC Output
  + AC Inverter
12 41 53 100% 73% 27% 77.76 1 77.76 13.48 17.34% Grid (Not-Plug-in)
Solar (Not-Plug-in)
NO
08 Base Standby
  + Bluetooth/Wi-Fi
  + AC Inverter
N/A 41 41 100% 81% 19% 54.72 1 54.72 3.64 6.65% Grid (Not-Plug-in)
Solar (Not-Plug-in)
NO
09 Base Standby
  + Bluetooth/Wi-Fi
  + DC Output
12 N/A 12 100% 91% 9% 25.92 1 25.92 4.56 17.60% Grid (Not-Plug-in)
Solar (Not-Plug-in)
NO
:gear: Settings
  • Charging Mode: Turbo
  • Power Lifting: OFF
  • Screen Timeout: 30 s
Working Mode
  • Customized UPS
  • Charging: ON
State of Charge Profiles
The current seasonal setting is Autumn.
Season SoC Low SoC High SoC Solar Reason
Winter 20% 85% 100% Longer nights, cooler temps — allows higher top charge
Spring 20% 80% 100% Balanced daily cycling
Summer 30% 70% 100% Protects against high-temperature stress
Autumn 20% 80% 100% Balanced daily cycling
Time of Use (ToU)
Period Time Range Mode Charging
Night 00:00 – 07:00 Peak NO
Morning 07:00 – 09:00 Off-Peak YES
Daytime 09:00 – 23:59 Peak NO
ECO Mode
Mode Status Threshold Auto Shutdown
AC Disabled < 10 W 1 Hour
DC Disabled < 5 W 1 Hour
Firmware Versions
Module Status Installed
IoT Up to date v8024.11
ARM Up to date v2203.08
DSP Up to date v2202.11
BMS Up to date v1087.05
