Floating Ground when off AC power
Like my Ecoflow unit, my new Bluetti AC200L has a floating ground when not connected to AC mains power, with the 3-pin plug. Some of my devices require the presence of a ground to function. If the ground check fails, they won’t operate.
I have or at least had one of those Neutral to Ground shorting devices. I can’t find it right now and am wondering if there’s a better way to go about this now. Why do these units float the ground pin?
This is the 120V North American version of the AC200L.
Thank you!
You can simply purchase a neutral grounding plug on Amazon to resolve the issue. If you have any other questions, feel free to reach out!
Uploading: 9a5685ff748102615fbefae9b11bec37.png…
Thank you. Are there any problems with keeping the Neutral Grounding Plug in the unit all the time?
Hello, there no problems with keeping the Neutral Grounding Plug in the unit all the time
Ok thank you. It just seems like there should be a better way.
