The Elite 400 needs to have a setting added to better regulate the incoming AC grid flow. The Elite 200 allows reduced AC grid flow so the battery can be charged on shared circuits. The Elite 200 offers the incoming amps to be adjusted under advanced functions. The Elite 400 is limited to adjustments of the Charging Mode between Silent 1000w, Standard 1200w, and Turbo 1800w. A 5 amp (600 watt) setting needs to be added in the advanced functions if the specific amp adjustments cannot be added. The Elite 400 lacking this feature is a step back from the Elite 200.
UPDATE:
Apparently the Elite 400 has the feature but it’s located in a different place than the Elite 200 under Charging Mode - Custom. I received this information from the fine people at Bluetti Support. Problem Solved.
