I would suggest and request a simplified Bluetooth app controlled expanded UPS mode(s) for the AC180T series. If I want to use my AC180T (I have two) to run my computer gear with battery power, I have to monitor SOC versus simply setting the unit to switch to grid power at a 20 percent charge. I charge one set of batteries via PV, and bring them in and swap out with the computer connected set.
Suggestions have been received, but the technical team has indicated that it is less likely that models with relatively small capacities will be planned to do custom UPS functions. ![]()
Doesn’t need to have all the custom features like the Elite 200. Just a simple PV priority and SOC floor where to AC180T switches to the grid at a set SOC (say 20%). Thanks….
Roger that, I’ll forward your adds to the team as well.
Thank you very much.
