Fast charging an AC200P
Looking for suggestions to fast charge an AC200P while driving. I’m an overlander with a 2020 Tacoma Offroad. Would a Victron Energy Orion 12/24-Volt 20 amp DC-DC Converter Non-Isolated work? This a link to a video I saw that gave me the idea: https://www.youtube.com/watch?v=4KS6aFCkGS4&t=17s&ab_channel=T4RGarage.
While AC200P is limited to 12A on solar input, the car charging is limited to 8.2A:
(source: AC200P manual)
Now when it comes to isolated vs non isolated, my understanding is that non-isolated would be enough: only sensitive equipment (medical, radio, etc.) would need isolated ground (more here):
Nice video.
However, slight mistake about AC200MAX, checking the manual reveals it is also limited to 8.2A on car/DC input:
The video uses the solar input spec, which in this case is quite different:
@BLUETTI , can you confirm that even though Solar takes up to 12A on AC200P, the same device, in pure DC input (no solar, simple car charging) is indeed unable to take more than 8.2A ?
I guess the MPPT and direct DC charge controllers are separate components, with their own specs.
So the Victron won’t fast charge because the AC200P can only take 8/2A of current.
Thank you.
Correct. You need to get a 12 to 48 volt step up converter to increase the voltage.
Thank you for the reply. I found another solution. The PECRON 500W Car Charger DC1242-500 for cars. It tricks the AC200P by using the PV connection which can take 12A. The AC200P setting needs to selected for PV charging. This is link to vid on the DC1242-500. https://www.youtube.com/watch?v=NqnYaqMwktE&ab_channel=Jasonoid-SolarPower%2CBatteries%2CandMore!. On the PECRON under Support / Manuals at the bottom of the page there is PDF for car charger user tips that is not included in the manual.
The pecron unit you mention is an example of a 12 volt step up converter. In this case, it steps up 12 volts to a 42 volt output. The higher voltage output is what allows you the higher charging rate not the 12 amp input.
Can you recommend some tested and proven to work with AC200Max?
I usually carry my AC70 or AC180 in vehicle, however, I also have the AC200P. The 70 & 180 have 3 mode AC charging, their silent mode setting is <300W. The AC200P uses its charging brick, which is 500W. I have an Aux LiFePo4 battery in the rear of my 4x4 and already owned a Victron 375W 240VAC inverter. (This scenario will also work with U.S. 110-120VAC).
The inverter is installed in my 4x4 and can charge the 70 or 180 from AC supply. At a pinch, I could then use either of them to charge the AC200P.
The AC200P at 500W is beyond the inverter output W. However a 600W or larger will do the job. Victron do an 800W. Enerdrive, produce a 600W PSW inverter. The other benefit of using a vehicle mounted AC inverter is that other battery chargers and small appliances can be powered in vehicle. I have a small kettle, toaster and toasted sandwich press, that all work from the Bluetti AC70’s 1,000W inverter. (Not my small 375W inverter). The cabling and fusing to convert DC-AC for an inverter is similar to other DC-DC chargers of the same wattage.
I would be waiting for this new release from Bluetti, which looks to be a perfect solution:
but isnt the 200P and 200Max limited to 12A and 15A only respectively?
