Does anyone know where or how I can obtain a extended P090D cable ?
Hi @Alfin
You cant buy this cable from a third party manufacture and bluetti only offer a single size for them.
So there is no way, in obtain a longer P090D cable. sorry.
Hi @Alfin, We regret that we are unable to assist you.
Yes, we appreciate @Selfmadestrom’s explanation. Our P090D cables only come in standard length, with no extended version available. Additionally, these cables are developed in-house, and no third-party alternatives exist.
Excessively long cables would lead to increased power and conversion rate losses, which we believe would not be cost-effective.
While Bluetti does not offer a longer P090D cable, possibly Bluetti will sell you two or more input/output ports, that can be wired into a homemade junction box.
This would function so as to let you add an additional cable. I would probably get a licensed electrician to assist. Make sure the power passes through the junction box correctly.
This could also be accomplished using two B300K batteries, along with an additional P090D cables, thereby providing you additional length that you are looking for. I hope this helps.
