Explore the Differences Between B300K/B300/B300S/B230
:thinking: Still on the fence about the B300K?
Got questions or concerns? Drop them in the comments below! We’re here to provide the answers you need and help you make an informed decision.
Most of the desicions made for the B300K make sense. Im kinda was worried about the missing power bank mode. But it abolute make sense, that this unit not support it. Recharge is not possible by itself, like B300 or B230 and its connected to a unit anyway.
But there is one thing, im really curios to know why it was made. The 12W USB-A.
USB-C would be the most common interface these days. The 100W USB-C is amazing. But maybe there is a technical restriction to choose USB-A. Fine. But why choose 12W instead of 18W like on every other extension battery?
Very useful precision on the powerbank mode in the comparison table !
A suggestion:
-replace “DC input” with “Solar Input” to avoid perharps some misunderstandings ;
-for the B230, in line with what is indicated for the B300 and B300S, delete perhaps the 500W indicated for DC Input/Solar Input of the B230
Is there an error in the Canada post below the comparison chart above? The B300K supplies 2764.8Wh, but the words talk about “an extra 3,072Wh capacity.” Doesn’t the 3072Wh only apply to the B300 and B300S?
Something else worth mentioning in the comparison table is that, at least in the US, only the B300 and B300S qualify for a 30% tax rebate since they both exceed the required 3000Wh level needed to claim it.
The product definition of B300K is designed purely as a battery pack, so only the USB port with a lower power consumption of 12W is included for emergency power. The need for a USB-C port will be considered in future product development. :)
@TMan Thank you for your reminder!
Currently, the B300K CA purchase page shows no issues and is displaying 2764.8Wh.
I have notified the CA sales team to correct the display error on the link preview page ASAP.
I came across this post when researching adding another B300S to my current AC500 1x B300s set up. The IOS app is showing the B300S as discontinued / out of stock, and the B300K was recommended. However I originally purchase my B300S for fringe (cold) season camping because it has the onboard battery heater. The B300K does not offer this feature. So WHY are you discontinuing the only model that has heating?
IF I decide to add a B300K can i use it with my current AC500 1x B300s set up consideriing the different battery capacities?
@Pat-Young No problem, the AC500 can connect to both the B300S and B300K simultaneously.
Hi guys! What about supporting old setups?
I’m using ac200pl+b300 and now it’s near to impossible to find one more b300. Can I connect b300k to b300 and to ac200pl?
Thank you!
I mentioned here that b230 is actually quite compatible with apex300 just does not have the config to read b230 capacity in order to determine total SoC
It would be awesome if you could push an update to apex300 to address that and make it compatible with b230:
Is there any limitations of the b230 with the charger 2 being the parking battery? I am seeing G053 error code when plugged into charger 2 via P090A port cord into BAT connection of charger 2. Can Bluetti confirm there are no limits of b230 as parking battery? I do see it listed as supported in the manual but this error code has no online documentation
