expanding the AC60 DIY
I’ve read someone’s thread about using a DIY 12V battery to boost or expand / charge their Bluetti AC model but it was a higher capacity unit than my AC60. Meanig it could handle higher voltage inputs etc. Ive read about using a 12.7V lithium battery rated at 100 AMP Hours as an expansion / charging host for the ac60.
The price is way cheaper than the B80. I figured I would make a cable that started with ring connectors to MC4 connector, and then use the provided MC4 cable that terminated at the solar charge input port of the AC60.
Will this work? I believe the max voltage input for the AC60 is 28V and of course 200 watts (limit of solar panels if I were to go that route)
So, is this doable, or would I need a 12V to 24 V DC to DV transformer? (someone mentioned this in an other post. Would 10 guage wire be correct? and would the provided bluetti MC4 adapter cable handle that that battery might output? Should it be fused along the way?
Sorry if this topic has been hashed to death. I couldn’t find it specific to the AC 60 unit.
Shannon
I would also like to know this. AND Why did the Bluetti AC60 website just say the AC60 is discontinued and then suggest the GIGANTIC “BLUETTI Pioneer 150 (AC240) Portable Power Station” as a substitute??? I’m planning on buying AC60’s (and B80’s) in quantity as power for a product we are developing and the AC240 is FAR TOO BIG!!! - And while I’m at it here. How many B80’s can a AC60 support? I thought I once saw a pic of three B80’s connected in series to a AC60 which would be desirable. Thanks in advance… - Jim
@JamesDTaylorSTL Thank you for your love for the BLUETTI AC60! The AC60 is still in production, and you can purchase it on our official website:
feel free to use the code - FORUM5OFF for an extra 5% off
A single AC60/AC60P can connect to up to 2 B80/B80P units, reaching a maximum capacity of 2015Wh.
Thank you so much for the quick and helpful reply. - Jim
You can also purchase an external lithium battery and have it supply the AC60 with 12v or greater power running through the solar connection as a power booster. As long as the ac60 doesnt consume faster then it charges, its a great way to extend its life.
