Expand AC180 with additional battery B230.
I want to connect my AC180 to a B230 and the P090D To DC7909 cable. The additional battery B230 is charged via PV350. Will the AC180 now charge at the same time? If so, with how many watts?
Thanks for the help
Hello
What I can say about it (but Bluetti will certainly answer you better than me) : I have a BC230, a P090D to MC4 cable which will power not an AC180 but a grid tie inverter. For the B230 to deliver power, you must put it in POWERBANK mode (long press on the power button and then the button flashes). What I observe is that the B230 manages to deliver a maximum of between 550 to 560W to my grid tie inverter (so in your case, to the AC180). What is interesting is that in POWERMODE mode the B230 recharges well from my solar panels (connected to a D050S charge amplifier). This is what I can say about it.
So the B230 is charged with solar or electricity in POWERBANK mode and the AC180 gets a maximum of 500 watts. Thanks for your answer.
