ESP500Pro - Is there a method to reduce the charge from the grid?
When I want to charge my EP500Pro from the grid I noticed that it consumes up to 2kW, but I would like to reduce it otherwise I cannot use other electrical devices. For example I prefer to charge the Bluetti during the night using less power and more time.
Do You think it is possible?
Thanks in advance
Hi @Alessandro83
You can manage the powerdraw from the grid by reduce the Amps in the Settings. With the timer feature you can also set when the bluetti charges and when it discharge. The only thing is that you cant change the Amps value reagarding the daytime. So when you set it to 1A it charges 1A in the day and in the night.
