I have an error code showing up, 041, as I am trying to charge my AC200p with solar. It’s about 15F at night and we are having bright sunshine during the day. This is preventing us from using the product as we need. I would also like a complete list of codes and fixes as well. Any help is welcome! Thanks.
What about the error codes listed on the main display screen menu. There are 5 or 6 screens of codes.
Thank you, that is where I found the 041 code, but I would like to know a bit more detail on the code and what the fixes are. Right now, every time I go to check, the error code is on and the battery is not charging with my solar panels. It’s cold here, and this is a problem, I need the battery for heat in the camper. Thank you.
I think the 041 error is relating to the AC200P being too cold to charge. Perhaps if you warmed the unit up for several hours and then kept it within its temperature operational parameters it would resume normal function. The good thing is that you only need to warm it up for several hours to see if this is the problem.
That’s an option. The problem with heating up the Bluetti in a camper van is the Bluetti fires up our furnace. This battery is in the cold, but well within the specs in the manual. It’s not even that cold right now, what happens when it’s really gets really cold?
Thank you,
Mary
You won’t be able to charge at less than 32 degrees F. What temp were you thinking the operating limits were? You can pull a load from the AC200P at lower temps, but charging will not occur.
Thank explains a lot. I wish I had known this prior to purchase. And in reading the manual it is not clear it doesn’t charge below freezing. After a day in the snow, we come back to a cold van, that explains the code. I’m reluctant to keep the furnace on unattended. I’ll tinker with it and let you know how it goes.
Thanks for the help. Is there a list of codes/explanations and fixes? That would help in the future.
Mary
