Hi everyone,
My EP760 is professionally installed by an electrician. The CT clamp is placed on L1 with the arrow pointing towards the grid (outbound). However, the EP760 does not show the home consumption in the app.
Manual feed-in and charging via the app work perfectly fine.
Has anyone experienced this issue or knows how to fix it?
Thanks in advance!
Hi,
Thank you for reaching out!
It sounds like the CT clamp might not be positioned correctly. For accurate home consumption readings, the CT clamp should be installed after the main circuit breaker to monitor all loads effectively. If it’s placed incorrectly, it may not detect the consumption properly, which could also affect battery output.
Please refer to Case 2 in the user manual for troubleshooting steps. I’ve sent you a direct message with the relevant page from the manual for your reference.
EP760 troubleshooting(10).pdf (3.1 MB)
If you have any further questions or need assistance, feel free to ask!
thank you for the hint - i’ll check this with the electrican and will provide feedback here
