An update:
I’ve been experimenting a bit more and noticed some strange behavior in the schedule. The schedule doesn’t work as you would intuitively expect it to, or as it needs to.
I actually wanted to set the schedule for tomorrow morning, when I suddenly see that charging with the set value is starting after all!
For testing purposes, I set a time window in between to [Peak], as electricity may be expensive at that time and I want to feed it in.
Charging via the grid suddenly stops, even though a time window with [Off-Peak] is currently valid.
For me, this is clearly an error in the EP600 logic!
For testing purposes, I delete the time window, which should actually be ignored.
Charging via the grid stops, even though a time window with [Off-Peak] is currently valid.
For me, this is clearly another error in the EP600 logic!
One last attempt: I set the first time slot (from 00:00) to [Peak].
Charging via the grid starts again, and the current time slot with [Off-Peak] is still valid.
Why [Peak] is allowed at the very beginning but not in between, and why there can be no gap, is incomprehensible.
The idea, as described in the documentation, would be to buy electricity (charge = [off-peak]) when it is cheap.
But feed electricity back into the grid when it is expensive [peak].
But how is that supposed to work if there is no time window with [peak] in between, or no gap in the schedule?
Now in winter, I don’t want to feed any electricity back into the grid; I want to buy it when it is cheap, i.e., when everyone else is feeding it back (around noon). At the moment, however, I see absolutely no setting option that would allow me to be on [off-peak] for just a few hours at noon and not the rest of the time…
Now that it’s already past midnight, I see another error in the schedule. I set the time slot from 00:00 to [Peak] so that charging stops at midnight → it does NOT (!) charge continuously, regardless of whether it is [Off-Peak] or [Peak].
OK, I want to stop charging, so I turn off [Time of Use], but [Charge From Grid] is still on.
Charging stops as desired, BUT (!) from now on, the battery takes a “break”; it is still switched on and the SOC (38%) is above SOC Low (35%). Nevertheless, the house is powered exclusively by the grid and not by the battery. Why?
So I also have to deactivate [Charge From Grid], even though charging has stopped anyway. But otherwise the battery remains in “pause” mode and does not supply any power to the house ???
To be honest, I would say that the loading/unloading management via the schedule is a complete mess.
