Hi,
What should happen when I select Battery Maintenance in Advanced Settings? I selected Start, Agreed and nothing happened. Grid on, no load connected.
Thanks.
Hi,
Thanks.
@Qwerty
According to the technical team’s confirmation:
This feature has not been released yet. It can only be used after the battery BCU17 testing and verification is completed without any issues. But the available time has not been announced yet.
@Qwerty The tech team has previously upgraded your two B500 battery packs to BCU18, and you can now use Battery Maintenance.
Yes. Program ask to start this.
But how long maintenance process?
Sorry, don’t mention “process” in first question ![]()
@BLUETTI
Discharge battery to grid with Feed to Grid OFF was unexpected :)
With Feed to Griid 2kW per single phase will take more than half hour. For 2 b500 possible take 1.5-2 hours.
Additional question:
Is battery should be fully charged before test? To 100%
It was 80% and start from discharging (feed to grid
Possible I should change working mode to 0-100% ? Or no difference?
Thanks.
No settings are required. The battery automatically charges and discharges during maintenance, and this can be done once every six months.
Ok
But usually battery test
So start from discharge looks strange.
Ok, will try “as is”.
Ok. For 2 B500 maintenance was ~4 hours
(Discharge 5.6kW, charge 4.5kW)
Battery was discharged to 0% and then charged to 80% (soc high level in working mode). Have to set high level to 100% to continue.
After 100% maintenance write “Complete”. Expected a little more results
something like: You battery health 99%, charged XX kWh, discharged YY kWh and etc.
Hi @BLUETTI
More than year passed… ![]()
Yesterday or day before yesterday EP600 ask about battery maintenance. At evening I started process. It has discharged batteries and started charging. At morning no any “reports” and EP600 asking start maintenance ![]()
Is it possible that grid loss could interrupt process?
Thanks.
Hello, this is a loop. You can ignore the subsequent maintenance reminders.
