EP600 ability to launch generator using dry output DRMs
Have a question, while reading manual found NO\NC output in DRMs connector, can it be used to launch generator?
How exactly it works? When SoC low it will launch generator?
Also inside manual states that EP600 can be cconnected up to 16B500, im currently have setup with 2EP600 + 8*B500 and thinking about connecting additional B500, will it work?
Im not in German, so power limitations iisn’t applied.
@Olvrick
The EP600 currently does not support automatic generator startup through the software. After connecting two EP600 units, a maximum of 8 batteries can be used; if more are connected, the software does not support it.
