EP500 refuses to charge
EP500 isn’t charging at all when I’m charging from the wall, powered by home batteries. The issue fades away as soon as I use grid. Is there a specification to what kind of charging the EP500 likes? Thanks
It sounds like the issue could be related to the power source compatibility or settings. Check if the EP500 has specific requirements for home battery charging versus grid charging. It might also be worth consulting the manual or contacting support to ensure your home battery setup matches the EP500’s charging specifications.
  1. Please for the love of god, STOP USING CHATGPT
  2. I would, if I could find the charging specifications
  3. STOP USING CHATGPT
