EP500 AND EP500 PRO Charger
Questions please. Will the same charger 500 watt I believe work with both units?
Second question. Can you connect the transition box with outlets between the 500 and 500 pro? Forgot exact name of it. Hold the 220 and 110 outlets
Transfusion box
The 500w external charger should work with both versions of the EP500. The Fusion Box can only be used with like versions. You can’t pair an EP500 with an EP500Pro.
Thank you. I will only order 1 then.
To connect two EP500 series in parallel configuration, both units have to be the same model…EP500 + EP500 or EP500 PRO + EP500 PRO.
Not sure about the charger being compatible with both units
