EP2000 constant Grid Consumption
Hello
i recently got an EP2000 and its working fine. But i have seen that the grid-side constantly consumes power even if the batteries are 100% full and im using about 200W from the Backup side.
As seen on my power meter (actually i have two, one for the EP2000 and one from the grid-supplier) I have a daily consumption of about 3kWh. This looks rather high, do i miss something?
Shouldn’t it be near to nothing?
My setting are 1A max from grid and no grid feed.
@Barf
May I ask for your EP2000 serial number? If the firmware hasn’t been updated, the old password is 159873. After entering the password, set up the meter address following the video tutorial.
Then, update all firmware to the latest version and check if the self-consumption issue improves.
Hi,
thank you for your quick support. I’ll check the serial number when I’m home.
I forgot one thing. My delivery was and is still missing the external power meter. May it has something to do with that? I’ll ask my supplier again if he can find out when I can get it.
Or is it not part of the delivery for Germany?
I’m not entirely sure about the details of the dealer’s package, you’ll need to confirm this with the dealer directly.
And yes, this accessory is compatible with systems in Germany.
Hi
for everyone watching. With the external Power Meter the consumption dropped to about 1kWh/day.
