Where do I get a car charger cable that plugs into the 12 volt DC port/socket in a vehicle and the plugs into the solar charger input for the Elite 200 V2?
I see one currently for $19.90 on Amazon and the bluetti website but am unsure if it is compatible with the Elite 200 V2. Also, what is the length of the cable? Also, obviously only charge it while the vehicle is operating as otherwise it could drain the automotive starting battery?
@sacrilegious
You are referring to this cable, right? This one is not compatible, and the length is 720mm. You need to purchase a charging cable with a cigarette lighter to XT60 port to be compatible with Elite 200V2.
