Hi all. I’m new to this so please bear with… Using Bluetti 350w portable panels for first time to charge Elite 200. Is it normal that the input generation reading on the app jumps every second from say 280w down to 100w then back up to say 250 etc etc… up and down like a yoyo… Nice sunny day no clouds. Thanks
Solved… bad lead connection :)
Based on your description it sounds very likely like you are experiencing MPPT hunting.
A) Update your firmware to address efficiencies in MPPT charge controller
B) Make sure the panel is not micro-shaded
C) If you are using extension cables (MC4) make sure you have the proper gauge for your cable run. Likewise make sure connectors are clean as well obviously and properly connected (i.e. they make that audible click sound)
