Hi @Ananas, we fully understand your concern, but we do not keep specific records for this, so we cannot confirm which batch your serial number belongs to.
Since you placed your order recently, your unit is most likely from the latest batch. Please use it with confidence. If you encounter any issues, you can contact us or the seller anytime for support.
Hi @rostifaner, I appreciate your interest in BLUETTI.
The Elite 100 V2 and Premium 100 V2 are identical in both hardware and software. They only differ slightly in appearance and printing.
These two models are the online version and offline version, sold on different channels. Apart from that, they are basically the same.
The Premium 100 V2 has a slightly higher maximum DC output, by 100W.
When we ship to our Ukrainian distributors, we also source the goods from our European warehouses. So it makes no difference where you purchase it. We take full responsibility for our products.If you encounter any issues, please feel free to contact us anytime for support.
I have two Elite 100 V2 units with issues, both purchased on Amazon Spain and sent to my family in Ukraine.
The first unit (S/N: EL100V22527004062845) shows error E065 on the DC output, and all USB ports stopped working. Firmware versions:
ARM v2186.16,
DSP v2200.16,
BMS v1083.08.
Steps already tried: disconnecting all loads, restarting the unit, updating firmware, and enabling DC with no devices connected - the error appears immediately every time.
The second unit (S/N: EL100V22527004430952) discharged to 5% and then became completely unresponsive. It does not turn on or charge from AC or PV.
Steps already tried: charging from AC and PV for more than 1.5 hours, keeping the unit at room temperature, warming the ventilation area - still no response at all.
Both units are currently in Ukraine and used daily during power outages, so sending them back to Amazon for replacement would take a long time and leave my family without essential backup power. I’m looking for a practical solution to get at least one working unit as soon as possible.
Any advice on how to proceed would be greatly appreciated.
Hi @Andrei, we recommend you try DC charging to wake up the battery first. If that doesn’t work, a repair will be needed.
We have promised with ITP Service LLC and confirmed that we will cover the repair cost for the Elite 100 V2 no-power issue. They will not refuse service, regardless of whether you have a repair card.
We do not provide separate parts delivery, as improper handling by non-professionals may cause further problems.
We hope the repair process goes smoothly. Please send us a private message if you still need assistance.
Hi @Star, thank you for the detailed information you provided. It seems to be a button abnormality on the Elite 100 V2.
E006 indicates a grid error, which is most likely related to unstable grid power. We recommend you keep observing. If the issue persists after using a voltage stabilizer, we will arrange a repair for you.
@BLUETTI_CARE.
I dont know how to use this website so replying to firat post. I have a Bluetti elite 100 v2. I use it mainly as a UPS for my pc. I bought it new from.amazon November 2025 and it stopped powering on February ,28,2026. It showed symptoms listed:
-It would not power off as long as it had power going to it for about a month after each use.
The number of clicks changed from one to three after the update last month
As of last night February 28, 2027 it stopped powering on like everyone else (if i knew the ups was a risk for this device i would have just used it as a solar generator, bluetti should notify customers to stop using it as a ups in the app or something)
Anyways the last power down was strange the system after use was plugging in the wall and would once again not power down, so i unpluged it but it still refused to shut down. The AC was shut off as thats what was being used and it refused to shut down. The button was held as indicated to force shut down and it did but since then it dows not power on when plugged in or button is pressed. The screen does not light up at all. No sounds either. Appears completely dead.
I would like a solution to reset it or get it to start if one as been discovered. The device is pretty new at 3 momths in my opinion and it has not been moved since i got it . No additional traveling.
Hi @grifild, thank you for contacting us.
I have discussed this with our engineers, and we all agree that this unit needs to be repaired.
Could you please click my profile to DM and provide us with your order information and email address?
We will arrange the warranty service for you.
Finally my device “occasionally” is also dead.
To be honest, I’m wondering is it legal to sell products, if they have massive hardware failures in Europe.
Especially it was purchased directly from online bluetti shop in 2026, at least 2-4 month problem was existing.
Hi @Lagros, thank you for your update.
This video requires permission to view, and we have already sent a request. Our email domain is poweroak.com — please keep an eye out for it.
Hi @nlogic, we fully understand your feelings. The issue with your Elite 100 V2 has indeed caused you inconvenience, but please rest assured that we will take full responsibility for your order.
According to our current data, sales of this model in Europe are much higher than in Ukraine, while the failure rate is significantly lower. Our analysis suggests that the unstable voltage and frequent power outages in Ukraine have triggered these problems. Therefore, we believe our sales are reasonable and legitimate.
If you need further assistance, please click on our profile and send us a private message, and we will arrange a repair for you.
I already reach out to support via email. Lets see how it will be resolved.
Unstable voltage - it’s not a case for me. In my region I didn’t notice any unstability in terms of voltage power values.
Key difference - it’s that here in Ukraine those devices are used on daily basis. That means that it is much more chance to that issue occur here than for avarage user in Europe.
Sorry. Access granted.
Hi @nlogic, thank you for letting us know.
Please let us know if you need any further assistance.
We fully understand your situation. In Ukraine, a stable power supply is crucial, and we hope everything goes well for all of our users.
We have also passed your feedback to the technical team, who will conduct further discussions on this matter.
Hi @Lagros, thank you for your update, now we have checked your video.
I can’t find how to send a private message in your profile.
If it’s truly the case, we have a much bigger problem then.
You see, since 2022, when this thingy with the power outages began here, the total amount of Bluetti units sold probably reached 6 figures already. Mostly models from the previous gen, of course (AC180/180P, AC200/MAX, AC200L/PL, AC70, EB3A etc.).
And none of these models drop dead en masse from unstable voltage, like this one. Your two main competitors also haven’t encountered this problem.
So, you’re basically telling us that Elite 100 (or one of its crucial components) is less resilient to voltage fluctuations than any other previous gen Bluetti model, and it’s unreliable.
Just my 2 cents and food for thought for your engineers and upper management.
Hi @Lagros, please don’t worry.I will send you a private message next, so please keep an eye out for it. We will follow up on this matter via private message.
Hi @VSM, thank you for your concern and reminder about this matter.
We take it very seriously internally and have been following up on customer feedback.
At present, everything is still within normal range, and we will continue to respond proactively.
Please rest assured that we are responsible to all users who choose our brand.
We have also passed your opinions on to the technical manager and other senior management.
Technical issue report — RFID UHF module interference causing BMS freeze on Elite 100 V2
Hello BLUETTI Technical Team,
I am writing to report a potentially widespread technical issue affecting BLUETTI Elite 100 V2 units operating in Ukraine, and to propose a specific solution.
Observed issue: Multiple Elite 100 V2 users in Ukraine are experiencing identical symptoms — the unit becomes completely unresponsive after being switched off, with no display, no sound, and no relay click. The unit occasionally recovers after several hours without any intervention.
Proposed root cause: The Elite 100 V2 contains an RFID UHF module operating at 865-868 MHz (EU frequency range), connected directly to the BMS board. Ukraine currently has intensive electronic warfare (EW) activity operating at high power levels (50-100W+) across various frequency ranges.
It is our theory that powerful RF interference on or near the 865-868 MHz band induces parasitic current through the RFID antenna into the BMS board. This interference appears to cause BMS freeze specifically during power-on/power-off transitions, when the BMS is most vulnerable to unexpected input signals.
This would explain:
- Why the issue is reproducible and widespread in Ukraine but not reported in other countries
- Why the unit occasionally recovers on its own after several hours
- Why the trigger is always the act of switching the unit off
- Why remote BMS reset does not provide a permanent fix
Proposed solution: We kindly request that BLUETTI engineers investigate this theory and consider implementing a firmware update that allows users to disable the RFID module via the BLUETTI app. This would be particularly valuable for users operating in high RF interference environments such as active conflict zones.
Disabling the RFID module would not affect any user-facing functionality, as this module serves logistical purposes only and is not required for normal operation of the power station.
My case details: Serial number: EL100V22545111478467 Support ticket: #467999 Location: Ukraine Firmware: v2186 (latest)
I am happy to assist with any testing or provide additional information if needed.
Thank you for your attention to this matter.
Best regards. @BLUETTI_CARE
