Hi @Lagros, thank you for your update, now we have checked your video.
I have discussed this with our engineers, and we all agree that this unit needs to be repaired.
Could you please click my profile to DM and provide us with your order information and email address?
We will arrange the warranty service for you.
I can’t find how to send a private message in your profile.
If it’s truly the case, we have a much bigger problem then.
You see, since 2022, when this thingy with the power outages began here, the total amount of Bluetti units sold probably reached 6 figures already. Mostly models from the previous gen, of course (AC180/180P, AC200/MAX, AC200L/PL, AC70, EB3A etc.).
And none of these models drop dead en masse from unstable voltage, like this one. Your two main competitors also haven’t encountered this problem.
So, you’re basically telling us that Elite 100 (or one of its crucial components) is less resilient to voltage fluctuations than any other previous gen Bluetti model, and it’s unreliable.
Just my 2 cents and food for thought for your engineers and upper management.
Hi @Lagros, please don’t worry.I will send you a private message next, so please keep an eye out for it. We will follow up on this matter via private message.
Hi @VSM, thank you for your concern and reminder about this matter.
We take it very seriously internally and have been following up on customer feedback.
At present, everything is still within normal range, and we will continue to respond proactively.
Please rest assured that we are responsible to all users who choose our brand.
We have also passed your opinions on to the technical manager and other senior management.
Technical issue report — RFID UHF module interference causing BMS freeze on Elite 100 V2
Hello BLUETTI Technical Team,
I am writing to report a potentially widespread technical issue affecting BLUETTI Elite 100 V2 units operating in Ukraine, and to propose a specific solution.
Observed issue: Multiple Elite 100 V2 users in Ukraine are experiencing identical symptoms — the unit becomes completely unresponsive after being switched off, with no display, no sound, and no relay click. The unit occasionally recovers after several hours without any intervention.
Proposed root cause: The Elite 100 V2 contains an RFID UHF module operating at 865-868 MHz (EU frequency range), connected directly to the BMS board. Ukraine currently has intensive electronic warfare (EW) activity operating at high power levels (50-100W+) across various frequency ranges.
It is our theory that powerful RF interference on or near the 865-868 MHz band induces parasitic current through the RFID antenna into the BMS board. This interference appears to cause BMS freeze specifically during power-on/power-off transitions, when the BMS is most vulnerable to unexpected input signals.
This would explain:
- Why the issue is reproducible and widespread in Ukraine but not reported in other countries
- Why the unit occasionally recovers on its own after several hours
- Why the trigger is always the act of switching the unit off
- Why remote BMS reset does not provide a permanent fix
Proposed solution: We kindly request that BLUETTI engineers investigate this theory and consider implementing a firmware update that allows users to disable the RFID module via the BLUETTI app. This would be particularly valuable for users operating in high RF interference environments such as active conflict zones.
Disabling the RFID module would not affect any user-facing functionality, as this module serves logistical purposes only and is not required for normal operation of the power station.
My case details: Serial number: EL100V22545111478467 Support ticket: #467999 Location: Ukraine Firmware: v2186 (latest)
I am happy to assist with any testing or provide additional information if needed.
Thank you for your attention to this matter.
Best regards. @BLUETTI_CARE
RFID frying the BMS due to EW makes more sense than the “unstable voltage and frequent power outages” bs they suggested here.
Explains why older models are totally fine - they simply do not have this module.
RFID was mentioned here before, as a prime suspect, but Bluetti provided no feedback.
Let’s see what happens now ![]()
Hello @BLUETTI_CARE ,
I’m having a serious issue with my Bluetti Elite 100 V2.
The unit worked for about 2 weeks, then stayed turned off for around a week, and now it won’t turn on at all.
I only recently found that this exact issue has already been reported by multiple users here:
I tried all the suggested troubleshooting steps from Bluetti representatives, but unfortunately nothing helped.
The unit was purchased in Europe specifically for use in Ukraine.
I bought it for my elderly parents as a backup power solution due to frequent power outages caused by the current situation in Ukraine.
Because of this, reliability and safety are extremely important for us.
When the station suddenly stopped working and became completely unresponsive, it caused serious concern.
This is especially stressful because the device was bought for emergency use, and it failed exactly when reliability matters the most.
At that moment, we were not aware that this could be a known issue, and due to safety concerns we carefully opened the unit to make sure there was no visible damage, overheating, or risk of short circuit.
We didn’t modify or repair anything inside — just checked for obvious issues and closed it back.
This situation could have been avoided if the unit had functioned properly and reliably from the beginning.
Since:
* this appears to be a known issue with this model,
* the device failed after a very short period of normal use,
* and it is used in a critical environment where reliability and safety are essential,
I would really appreciate your help in resolving this, specifically regarding the possibility of a warranty repair in Ukraine.
Thank you in advance for your support.
Hi @Sergey1, thank you for sharing your case and providing such a professional analysis. We find your insights highly valuable. We have forwarded your feedback to our technical and R&D teams for further discussion, and we will update you here once we receive their response.
Regarding the issue you encountered, we recommend contacting our local service center in Ukraine first. We have prepaid the repair fee for the Elite 100 V2.
If needed, please send us a private message to get the service center’s address and contact details.
This solution will be much faster than waiting for new firmware development and testing.
Hi @vseleznov, thank you for contacting us.
We fully understand your frustration and we are more than willing to assist you.
Please contact us via private message and provide your order information as well as email address. We will send you the address and contact details of the Ukraine retailer service center, and keep following up on your repair process.
Hello @BLUETTI_CARE, @BLUETTI,
Thank you for the quick response! I’ve tried to send a private message, but the option isn’t available for me yet (likely due to my account being new). Could you please initiate a DM with me? I’ll reply immediately with all the necessary details.
Hi @vseleznov, we would like to help you.
We will send you a private message right away as you requested. Please check your inbox.
Exact same issue. Was using it as a UPS connected to AC power. Hardly ever used the battery. I was going to perform the periodi maintenance discharge so I unplugged it from the AC power. It was still on then it turned off when I checked it the next morning. Tried all ther mentioned troubleshooting steps here but still couldn’t get it to turn on. Bought this in the Philippines and been using it for over 1 and half months (Purchased March 15 this year). I’ve reached out to the local support and dealers here through email but have not received any response. Even the seller I bought it from is not responding.
Thank you for any assistance.
Hello @BLUETTI_CARE I’ve got the same issue. Not starting up with button press, not starting with AC or DC power input. It was last working 2 days ago, was at 98% battery last time the app updated.
I have called your customer support line and apparently this has been escalated to support already, but I haven’t had any email confirmation. I can’t PM you, similar to @vseleznov
Could you please send me a DM, or just confirm that my support case is open?
Hi @tnwhitwell, I’m sorry for the delayed reply due to our busy schedule recently.
We have now sent you a private message as you requested. Please check your inbox and provide the service ticket number.
Thank you for your support and for resolving my case so quickly.
The whole process, including shipping and repair, took around 9 days, which honestly exceeded my expectations.
Everything is working perfectly now.
Really appreciate your help!
I bought this station in January on the official website in Germany. Now I have the same problem as most people - it stopped turning on with the button. I ask the Profile - BLUETTI_CARE - BLUETTI Community service for help in solving this problem!
Hi @vseleznov, thank you for sharing this good news with us — we’re very happy for you as well!
Please note that this forum will soon be merged with the app Community. If you have any questions in the future, please get in touch with us through the app Community.
The official announcement is as follows.
Hi @Feerie, regarding this issue, we recommend that you first try activating the power station using a DC power source. If this does not work, you will need to contact customer service for further support.
The email address is sale-de@bluettipower.com.
If you have any suggestions regarding response time or service efficiency, please provide your service ticket number so that we can further follow up and improve the service process.
Please note that this forum will soon be merged with the App Community. If you have any questions in the future, please get in touch with us through the App Community.
I’m sorry for little offtop, but could you somehow summorize situation with Elite 100V2 powering issue? I read dozens of fresh negative feedbacks for this model on the local marketplace and I’m curious: is that problem fixed? Is it safe to buy this model for UPS usage?
How could I check if station is up to date? which version of BMS is safe for use?
I have bougth one 6 months ago and it’s still works, but a lot of complains are dated near that operation term. And I got a bit nervous.
