EB70 temp error during charge
I have a problem with EB70 unit.
It is discharged - Alert Icon for low Voltage shown.
I’m trying to charge it but there is temp error appears on a screen and it is not charging.
Temp error showing only when charger plugged in(green idicator on charger ).
Outside is a room temperature.
What can be done with this issue?
Hi @Morte, Could you please provide the specific error code? It would also be helpful if you could take a photo and share it with us.
We recommend turning off the device and placing it in a cool place for 3 hours, then trying to load your equipment again. Does this help? If the issue is resolved, we suggest recalibrating the battery.
Welcome @Morte sorry to hear you are having a problem.
Is the error coming on after you are using it when discharging at a high load or is it there all the time if you have anymore info that would be great.
Ok. Temp error is gone.
But now there is a new issue(((
Infinite charging. Display shown 100% charge. But if charder unit is plugged in it starts to charge station (red indicator on chrager uinit is On, station screen show charging progress from 80% to 100%, collers are working ,etc).
Update: Will try to recalibrate
Recalibration solved the issue
Thanks fo comments everyone!
