EB70 Solar panels
Hi there,
I noticed that the EB70 can handle 200w solar input.
What will happen when there is a larger capable panel connected? WIll it just charge at 200 w max?
I am able to get my hands on this panel, (just one) But How am I able to tell if this would work? https://groothandelsolar.com/wp-content/uploads/2021/05/HYUNDAI-M6-SHINGLED-VG-60-SIZE_EU-and-AUS_FB-front.pdf
Hi Jelle,
The open circuit voltage of EB70 is VOC 12-28V.
You can’t use your piece of solar panel to charge the EB70, the open circuit voltage of your solar panel is 46V over 28V and will over-voltage the machine. Using the solar panel to charge the EB70 must ensure that it meets within the open circuit voltage range of the EB70. Hope this helps.
Nothing bad will happen. Your EB70 will only accept the 8 amps regardless of the incoming amperage available.
