Hi all,
I charged my EB70 fully overnight. Went to use it this morning with a travel kettle (600W) it said 100% charge on the screen when I started switched it on. I switched on the kettle and within 20 seconds the EB70 was flat. Does anyone have any advice?
Something is not right. Try charging it to full again and see. If it happens again, you may need warranty service. A 600w load should last almost an hour
Hi @Dolittlecampers,
Sorry for the inconvenience.
The kettle’s surge power or the setup power may surpass the EB70S’ power. Pls use the EB70 to power other devices and see if it is normal.
