I am trying to maximize the charge on my Bluetti EB55.
I tried the AC adapter + external 24v gel batteries (alligator clips/XT60) and it works fine = ~390W input.
Cigarette 12v car adapter (original) + AC works fine too.
But I have a Honda EU10i generator.
DC output is 8A rated.
Bluetti MPPT is 8A rated.
Bluetti works fine from AC output, 200W charging.
But when I try to connect DC to the MPPT port - it does not work.
Short video:
I checked the polarity - it’s correct.
I checked the voltage on the DC output of the generator = ~23-25V.
We need to charge the EB55 outdoors as quickly as possible, so I try to get at least 300W total input.
Any idea why it doesn’t work from the generator’s DC output?
@rgb
Good point. I tried yesterday with eco-mode ON.
So, I switched the eco-mode OFF, but the voltage goes higher, from ~25v to 35v (proof https://www.youtube.com/watch?v=rSnALubSUvs).
I am afraid to burn Bluetti with 35v. MPPT rated 12-28v.
Probably, should buy some DC-DC converter.
I had a small generator that was specific about how the DC was used, so I googled the model you mentioned and it does say to have ECO off when using DC, but it sounds like that does exceed the EB55 limits.
As Scott-Benson mentioned, you might just use the AC adapter since using DC at 25V * 8A = 200W, you probably won’t get much more than that, if at all, with a DC-DC converter.
Actually, looking at the specs again, if you do get a DC-DC converter AND use the AC adapter at the same time, you might get close to the max it can charge since the EB55 can charge from both AC+DC at the same time, up to a max of 400W.
@rgb@Scott-Benson
Yes, I want to charge Bluetti in parallel, so 200W from generator AC, + at least 100W from generator DC (Honda DC output is 8A, exactly as EB55 MPPT input). Honda allows parallel operation of AC + DC outputs.
Reducing the time of charging even an extra 0.5-1h is important for us.
So, finally, I realized why the voltage was so high on idle with ECO mode OFF. It’s normal for Honda EU10i according to the service manual.
I hope the DC converter (like 8-40v to 13.8v) will resolve the issue.
The issue was resolved. DC Converter 8-40 to 13.8 works fine. Charge + ~70W into MPPT input.
Together with AC Adapter, it’s about 260–270W. It’s not much but a good addition for emergencies.
Sorry for the sunlight, The Bluetti screen is not visible.
Another solution.
I have tested a Lenovo 170w, 20V laptop charger + a standard AC Adapter.
But it does not work stable with different EB55. On my first one, it works great +150W, a total of 350-360W.
On my second new EB55, it provides only 70-80W :(
