I purchased the EB3A a month ago. It was fully charged and today when my power went out, I found the EB3A had no battery power.
Once the power came back on, I plugged in the AC power cord and it charged up to 10% and stopped charging.
Can anyone assist me with this issue?
Hi @dianna216 , Did you charge it with the adapter and then stop?
If so, please try solar charging or car charging. If both of the above are charging properly, then there is a problem with the charging cable or adapter, please contact support for further processing (replace the adapter or AC charging cable)
I sounds like your EB3a may have been put away with the power not being off but the screen just being in standby which will drain the battery while in storage. Try draining the 10% left in the unit by powering up a device until empty and try re-charging again via AC. If that fails, see if it will accept a charge from your car cig socket and if not I would say time for a replacement.
Hi Scott,
I attempted to drain it to 0 overnight but at some point, it charged up to 7%.
I will drain it without it being plugged in.
My device did not come with the car adapter. Do you by chance sell them? or can I order them through Amazon?
I will let you know what happens tomorrow.
Thank you so much for getting back to me.
Dianna
Amazon sells the Bluetti car charging cable for $9.90 Amazon.com
All portable power stations will drain if left on even though no load is attached. Just powering up the unit consumes power and if left on in this state the battery will drain. Just because the display screen is blank this does not indicate the power is turned off. The EB3a screen automatically turns off (but the main unit is still on in standby consuming power) after approx. 30 seconds to needlessly attempt to conserve power. This feature should be adjustable but unfortunately Bluetti does not seem to understand the issues the short screen timeout causes and is unwilling to change even though it could be addressed and added to the EB3A with a firmware update. To fully turn the EB3A off you must hold one of the operation buttons down for a long press of approx. 5 seconds. To understand if your unit has an issue or not, we must first determine if you are fully turning the EB3A off or inadvertently leaving the unit in standby with no display on which will drain the battery.
Thank you for the link. I downloaded the latest firmware and was able to get the power pack to fully charge to 100%. I used the app to turn it off. Yesterday I had a power outage from 830am until 3pm! My Bluetti performed awesome. It kept my laptop and monitor and desk light on this entire time allowing me to complete my tasks for my job’. I am thrilled with its performance!! Way to go Bluetti!!!
Glad to see you up and running. It is a great little unit for the price and size.
Same issue with EB3A - I received two new devices, one at 54% and other at 57%. I left one plugged in to AC charge overnight and it has NOT moved a bit. Seems as though these were sent on/standby and I can’t seem to find a way to increase the charge on these? Note, The issue is NOT the cable (brand new from BLUETTI) and wall outlet is solid, charged up other battery backups earlier this week.
I saw others discuss updating device firmware, maybe that would help? Not sure WHY I would need to update a new device before charging but I’m new to BLUETTI and not sure HOW to diagnose firmware version OR how to update?
Thanks for any pointers you might have
Learned a LOT on this in last hour! Firmware is up to date, also tried turning on DC power thinking it is required but all videos do NOT talk about it needing to be on, although it must be on IF I want to connect and monitor via mobile app.
Crud, I’ll let it charge for awhile and see, but stuck at 57% for awhile now, not an issue with wall outlet or cable and firmware is up to date, or so the app —> firmware says.
Hoping others might have a trick to get this charge number to increase?
Thanks for your thoughts!!!
….Ryan
I’m an idiot, wall outlet looks to be fried. Didn’t know how to read UI/App and saw power from device to DC out and thought that was charge. Plugging into another outlet now shows active charging on device and wall—> device flow, finally getting the hang of this, damn wall outlet
