EB3A unit shuts down after 10-15 output connection to AC
My EB3A unit has been working well for a couple of years. I can connect to my solar panel and charge to 100%. However, in the last month whenever I connect more than a phone to the output, the unit auto shuts down after 10 - 15 mins and is unresponsive. I have to reconnect to the solar panel for it to reboot. What can I do?
S/N: EB3A2225001041166
Firware:
  • ARM v2057.06
  • DSP v2056.06
Thank you for reaching out.
  1. Error Codes: Can you check if there are any error codes displayed when the unit shuts down? This information could help diagnose the problem.
  2. ECO Mode: Also, please verify if the ECO mode is enabled. If it’s on, it can cause the unit to shut down more quickly under certain conditions, especially when the load is low.
If you can provide more details, I’d be happy to assist you further!
Thanks for the response!
1. Error codes: I got the following error codes when I was investigating a couple weeks ago:
  • 5606
  • 5706
2. ECO Mode: ECO mode is disabled.
Thank you for reaching out. It seems that the issue you’re experiencing may be due to a problem with the battery cells. We recommend that you consider replacing the device.
If you need further assistance or have any questions, please let us know!
Best regards!
Hi there,
This is pretty disappointing, to say the least. I’ve used the unit a hand full of times (less than 20) and it’s now “broken” and needs replacing (after three years, when the warranty is two years). Customer trust totally destroyed, and I’ve now bought a Jackery instead.
