Is it possible to get a firmware update?
EB3A2247000091743
Hi @syl
If there is nothing in the App, you cant update it without a direct update push from the Bluetti Devs.
When there is a newer Version available @BLUETTI can help you to push it to your EB3A
Hi Bluetti Care,
I’m experiencing a similar “overload” problem, running EB3A 2322001298882 in UPS mode. Running 2 low watt power supplies for a router and extender.
My other EB3A powering my CPAP has had no problems whatsoever, after upgrading the firmware, so I’m hoping for a firmware fix!
No, USA. Purchased directly from Bluetti website.
I didn’t get a firmware update - still on ARM 2053.07 / DSP 2052.04
Des
Hello, that worked. New DSP downloaded. Thank you.
Thanks for your update.
Good day Team, I’m getting the same OVERLOAD issue, please help
EB3A2333003098281
