Hi I use a small radio to listen to music in the kitchen, it runs off the mains or batteries and gives me a nice clear uninterrupted sound, but when I use the EB3a (ac) plug side I get a massive amount of interference.
The radio does have a suppression block on its AC cable is there any other way to reduce the interference whilst using the Bluetti EB3a?
Steve
Not sure, but what if you would use an extension cord and move the EB3A further away?
Hi @Reddragon
This is pretty normal and the case for almost every powerstation.
Its caused by the inverter. Do you have the option to power your radio by DC too? This should fix it.
The other only real option is to move it as far as possible from the powerstation
            Many thanks for your reply will give it a try.
Steve
            Thanks for that will look to see if there’s a 12volt option.
Regards Steve.
