This is my first purchase EB3A down loaded the app. I turned on Bluetooth and paired . A day later I needed to pair again. Why does it not stay paired more than a day?
@h1450
Bluetooth connection is distance-based. If your phone is too far away from the device, the Bluetooth will disconnect and you will need to reconnect again.
i understand what you are saying but this is happening in my house in the living room. the EB3a unit is on a coffee table and phone is in the recliner. I thought if paired once I should not have to do it over and over. Each time I have to turn the unit on and pair then works as it should.
