Should the ac charging info go from 0 to charging kw. It apparently shuts off then comes back on after a few seconds. The unit did charge but is this normal?
It still charged. It seems as though as it becomes close to fully charged it starts this zero to the current charge watts. Does this unit start to trickle charge the closer it gets towards 100% Is that the reason it does this?
