I search the forum but found on, EB240 not charging with AC charger. Charger green light and fan are on. Screen shows 2 bars and no input. thoughts??
Hi @darwal61
do you mean the fans of the EB240 are on or the fans of the AC Charger? Because they are always on.
Do you have a second AC Charger to test if its realted to the charger or the EB240?
Its normal that it show “green” when you first plug it in, it should switch to red as soon you plug it into the “empty” EB240.
@darwal61 Can EB240 be charged using solar panels? If yes, the AC charger of EB240 may be defective.
