EB200P compatible folding Solar panels?
Hello. I recently purchased a Bluetti EP200P Package with 2 x 12V Mono 200W Solar Panels. The system works fantastic. I am now wanting to add a folding solar panel setup for camping. I can’t find any information on the EB200P on the Bluetti web page. My question is will the BLUETTI SP200 or SP350 Solar Panels work with the EB200P. Thanks.
Kenny
Yes, either of those panels will work since the EB200P can accept 10-145 volts of solar.
From Amazons listing.
Technical Specifications
Model EB200P
Capacity 2048Wh
AC Load 2200W
Battery Type LiFePO4 (3500+ Cycles to 80%)
AC Input 500W
Solar Input Voc 10-145V / 900W Max. / 15A Max.
AC Output 6 x AC 100-120V
DC Output 1 x DC 12V/30A RV Port,2 x 12V/10A DC,1 x DC 12V/10A Car Port
USB Output 2 x 5V/3A USB-A, 1x 100W USB-C, 2 x 18W USB-A
Wireless Charging Pad 2 x 15W Max. (for each)
Charge Temperature 32°F-104°F
Discharge Temperature 14°F-113°F
Dimensions 17.3 x 11.6 x 15.3 inches
Weight 61.9 lbs
Thanks. I thought so.
