Hi,
I’m experiencing an issue with my Bluetti EB180 and I’d appreciate some help.
The unit charges fully without any problem, and the display shows 100%.
I then connected a small external cooler (~50–60W) to the AC output. It runs fine and discharges the battery to around 50%, and then suddenly I get the E011 error and the unit shuts down.
I tried to:
- Recharge it fully → it charges to 100%
- Discharge via USB with an iPad → E011 appears again after just 2–3 minutes
- Reset with long press → no change
The unit has only been used around 20 times and was never deeply discharged.
It seems like the battery shuts down even though there’s still charge left, and I suspect a BMS calibration issue or a faulty cell sensor.
Is there a way to manually recalibrate or reset the system?
Or do I need to send it in for diagnostics?
Thanks in advance for your help!
Best regards,
