I’m Mike and new to the Bluetti world. I have the EB150 and it will power my teardrop camper. I would like to remove the handle to fit the unit into a space that is built for it. Open front and rear so no airflow issues.
Has anyone removed the handle? If so, can I just remove the plug covers on the handle and unbolt it? Will the nuts on the inside of the unit fall into it or are they fixed to the case?
Thanks for any information.
Mike J
Fantastic reply. Thank you so much for the great video and efforts.
Thank you for the video. I couldn’t have a better or more complete answer than that. It’s also fantastic to know the layout of the interior.
Mike J
To OP: My pleasure! If that that crazy 7.9mm input jack is driving up the wall, it doesn’t look to bad behind that front panel to replace it. Same with expanding the A/C outlets in the back. Of course, wrenching on your solar generator like this will probably void the warranty.
