Dumb question
If I attach the B230 to solar panels and also the Max 200, once the 230 is filled does the electricity go to the Max until it reaches capacity?
Yes, you are correct, this is all controlled by the Battery Management System (BMS).
Just thought that I would add in here that you need to connect the solar to the B230 via a DC Charging Enhancer (D050S).
You may have already known this but just in case not.
