Dual AC Charges into AC200Max
Found this diagram of two AC inputs into the AC200Max. Are both of these charges the AC Charging unit or is one a Enhanced Charger?
Thx
Both are the ac Charging brick which converts 120 VAC to 58.5 VDC. The voltage can be used in both the normal AC charging inlet and the DC (PV) aviation input. The only thing required other than the extra charging brick is the 7907 transfer plug. This is a 7909 female to XT90 connector and is about a 6" long cable. It is listed in the accessory section of the main Bluetti site for $19.95. It is a great adapter to have since it can also be used to adapt to many different portable power stations as long as they accept a 58.5 volt or higher input and have dual charging capability. I have seen it used on Montek products as an external charger as well.
The input is greatly appreciated. Just pulled the trigger for the brick & 7909 female to XT90 connector. Already have the Aviation plug.
Thx again.
