Does not turn on AC DC Bluetti AC200Max
Good afternoon, dear Bluetti company.
They are bothering you from Ukraine. Our cultural center was given a Bluetti AC200Max charger last year. And recently, I can’t turn on DC and AC, bluetooth won’t turn on, it won’t turn on, and the time and date won’t change. No accidents are displayed. The menu is scrolled, information is displayed, the sound is turned on and off. Battery charge 100%. The display sensor is working. Suspect software.
On the back of the display there is a slot for a memory card, it is possible or not to update the software through it, because through the application I cannot connect to the device, bluetooth does not turn on (as I indicated earlier). And share with me the instructions and the firmware file.
Device information:
Model: AC200MAX
SN: 2243001028967
DSP Version: 4005.07
ARM Version: 4008.05
BMS Version: 1017.02
HMI Version: 6037.04
Thanks in advance.
@Nikolay The ARM firmware will be sent to your AC200MAX in 24 hours, please update the firmware and check.
Hello. I’ll put my two cents in.
I understand that Bluetooth is disabled on his Ac200max and that Nikolay can’t activate Bluetooth from the screen… If I’ve understood correctly, it won’t be possible to update …
Good morning.
Thank you for your answer. But I can’t turn on bluetooth on the charger. I need another way to update.
@Nikolay We’re sorry that firmware upgrades can only be done via a Bluetooth connection.
Have you tried doing a factory reset in the settings menu? If it works (I’m not sure it could be that the touchscreen is broken) it can activate Bluetooth because by default Bluetooth is activated I believe.
Hello Bluetti Team!
I have the same problem with my AC200 Max. AC/DC is not operational from the touchscreen. It click and beeps but does not turn on. Still works with Bluetooth app.
Can you send a firmware update to me please?
SN: 2240002755046
DSP: 4005.08
ARM: 4008.05
BMS: 1017.03
HMI: 6037.04
@Zhyrnov We are sorry that your machine version cannot receive the firmware. Please contact after-sales support for repair.
Hello Bluetti Team!
Recently Bluetooth has stopped working, the only thing that helps is turning off the AC200MAX completely.
Model: AC200MAX
SN: 2252000419236
DSP: 4005.08
ARM: 4008.05
BMS: 1017.03
HMI: 6037.04
Thank you for your support!
Hello Bluetti Team!
Model: AC200MAX
SN: 2302000652251
DSP: 4005.08
ARM: 4008.05
BMS: 1017.03
HMI: 6037.04
