Hey everyone,
while make my first video for the second generation of the balcony system, i mentioned that the system isnt able to provide a real “Zero waste” mode. Well, i built it myself and it works great since weeks now! I created a video to show you, how you can built it for yourself. It also should work with other systems ;)
Let me know if you have any questions, otherwise feedback would be appreciatet.
well done !
I measure the work necessary to integrate all the bricks, and I imagine the great satisfaction of seeing on the phone macrodroid all alone go to get the values and inject into the bluetti app ! It’s magical and hypnotic!
It was a lot of work. I do have all of the values, but to bring them into to right shape and actually use it like i do… there wasnt any guide that done something like this befoure.
Thanks @Snips1 ![]()
Yes! I think you are the first to do this with Bluetti/the balcony system and it is also the first guide so detailed !
Nice! Endless imagination has been in action
KUDOS!
Nice video and well described, thumb on YT is out. ![]()
I use HA with BT connection to my EP500Pro, sadly its not so stable actual. ![]()
Why is Bluetti not able to give us a WLan connection to HA? The WLan works much better here
and so the risk to loose the connection to the powerstation is less risky, cause a have made a emergency charging automation if the powerstation battery is less than 20%, then the HA activates a shelly plug for grid loading the battery up to 80%.
This MUST work here, cause my 2 fully loaded fridges are powered with the EP500Pro and I don´t
want to loose near 1000€ when they fail…
Thanks @BlueTobi !
Your right, bluetooth is far mar fragile than wifi. I really hope, when they launch their first model with official HomeAssistant support, that it doesnt depend only on bluetooth
Hopefully, the EP500Pro is a really good device and I like it except the BT problems and complicate HA integration.
May it last long, otherwise I must change the brand to get what I need and want…
