BLUETTI AC200ASTRO Portable Power Station | 2,400W 2,048Wh with 2 BLUETTI ASTRO Satellites
- Power Station and Satellites are IP65-rated Dustproof & Water-resistant (Astrophotography is an outside activity!)
- LiFePO4 Battery with 3,000+ Life Cycles to 80%.
- Power Station is temperature regulated for instant charging after those cold astrophotography nights
- Expandable to with up to 3 B300TK (temperature regulated B300K) or B300K non-temp-controlled expansion batteries ( we are powering up to 6 sets of astro gear, an RV, several computers and our temp controlled batteries!)
- Support up to 3 PV350 Solar panels (Some of the Star Parties and most other locations have no shore power)
- AC charging (When we do have shore power)
- Dedicated generator charging (for those cloudy days)
- BLUETTI App allows the user to specify primary, secondary and tertiary charging sources allowing source selection based on locations and conditions.
- Comes with 2 25ft Satellite Connection Cables
- Built in IP6 unmanaged ethernet switch (Much better than WiFi)
- 6 total 120v AC 20amp outlets (4 on the Power Station and 1 on each Satellite)
- 4 total 12v 30-amp DC outlets (3 on the Astro Gear Satellite, 1 on the Command Center Satellite)
- 4 total 12v 10amp 5521 outlets (3 on the Astro Gear Satellite, 1 on the Command Center Satellite)
- 4 RJ45 Ethernet jack on each Satellite and 1 RJ45 Ethernet input on the Power Station for internet access
- 1 12v 10amp Cigarette Lighter outlet on the Power Station
- 1 24v 10amp outlet on the Power Station
- 1 AC 30amp RV outlet on the Power Station
- Battery Tender switch on the Power Station that allows the user to turn on or off temperature control on all internal and connected batteries (with the temperature control feature) with displays that show the current temperature of each battery.
- Dark Mode switch that allows the user to change all the LED lights from the normal Green On, No Light off to Red On, No Light off as well as red backlight for the main display and power button ring when on. (A MUST for Star Parties!)
- Output Power Control buttons on the Power Station and the Satellites for all outlets.
- 4 solid rubber screw on feet for the Power Station and each satellite to keep your investment off the ground.
- 1 AC Shore Power Charging Cable
- 1 Generator Charging Cable
- 2 Satellite Connection Cables
- 1 25ft Internet Connection Cable (RJ45)
