dc overload ... ERROR A026
MY EB3A goes dead if not on ups, hit dc gets error A026 code, unplug from ac wall goes dead… plug back into wall works again says 100%
@bluetti_rmneswickmsncom When plugging in the AC charging cable, turn on the AC and DC buttons of the machine. After 30 minutes to 1 hour, the machine will drop from 100% to 99% due to self-consumption. After the SOC drops to 99%, unplug the charging cable. The machine works normally (it can be turned on even if the charging cable is unplugged). Then, re-plug the charging cable for charging. However, the SOC is not accurate at this time. It may take a long time to recharge from 99% to 100%. After it is fully charged, you can continue to use it normally.
私のEB3AもDCが過負荷がでて、使えません。
給電をしても100%の表示のままです。
DCはiPhoneの充電しかしてません。
まだ、買って2ヶ月で壊れましたか?
私もあなたと同じ症状です。
エラーは解除できましたか?
Hi @shinshinshin, For this issue, please try disconnecting all loads and then restart the EB3A. Does that help?
If not, please press and hold the AC and LED power button when the problem happened to view the error code.
If you need a repair, please message us with your order information, and we will arrange the warranty service for you.
全ての負荷を取り外しています
error code 0-00
困っております
everything has been removed
I’m in trouble
A026 0-00
Hi @shinshinshin, A026 indicates an overcurrent on the AC output. If this error occurs while only charging an iPhone, it seems unusual.
Could you please message us with your order number? We will arrange warranty service for you.
Official website, not AMAZON
Not an official website
NOT AMAZON
BLUTEEI_CARE!! Have you received a reply yet?
Hi @shinshinshin, Since the order number involves personal information, I am following up via Message rather than a public reply to protect your privacy.
We would like to know which store you purchased from and your order details.
I have replied to your message but didn’t get your answer after 3 days.
Also, if you need me to follow up, please @BLUETTI_CARE, otherwise I won’t be able to find your post or comment.
Hello, I purchased my EB3A from a personal seller on eBay. It was working perfectly for the past 6 months. Recently I left the unit in my vehicle and it must’ve discharged to 0%. When I went to recharge it using AC power I noticed the unit goes into UPS status and won’t charge past 1%. When I turn on both the DC and AC I get the error code A026.
