The USP output is not working, getting 14 fault code. What can I do?
Hi friend,
Sorry for the inconvenience.
AC200/P has no UPS. Could you please describe your problem in detail? A video or some pictures showing the problem would be much better.
What does the “14” fault code indicate the issue is when you go to the fault screen and look up 14 fault code?
USB PORT. when I tried turning on the DC and tried charging my iPhone.
Fault code 14: DC OUTPUT FAILURE.
