DC Charging from Honda EU100i
I want to charge an AC200P using DC out from a Honda EU1000i.
I’m not averse to building my own cable(s), but I’m wondering if anyone has any experience with this.
Thanks all.
The DC output of the Honda EU1000i is only 96 watts and would take about 20 hours or so to charge. Does not make much sense to me to have to run your gasoline generator that long. I would think using the AC charging brick at 400 to 500 watts would be a much improved charging experience.
Thank you. I hadn’t considered the generator total output at this point. I will just stick with the brick.
Not quite what you’re asking, but you can do a combination of charging, according to the specs.
AC Adapter (400W):≈5.5~6 Hours
Solar (700W): ≈3.5~4 Hours (With prime sunshine, ideal orientation and low temperature)
12V/24V Car Outlet (100W/200W): ≈10 or 20 Hours
AC + Solar (1100W): ≈2.3~2.8 Hours (With prime sunshine, ideal orientation and low temperature)
Solar + Solar (1200W): ≈2.1~2.5 Hours (With Optional D050S DC Charging Enhancer)
Dual AC (800W): ≈3~3.5 Hours (With Optional Dual Adapters)
