I accidentally reversed polarity and now D050S wont power up. Is it fixable?
Thanks,but the vid was two minutes to open the case and no idea how to locate the fuse
I’ll keep looking
I will not be able to help you a lot, my D050S is new and works well and I will not open it for fear of losing the warranty. This is why I put the video to you, so that you can see if it is worth opening. On the video I can see the fuse and the varistor. I will start there.
Which component shown is the fuse ?
fuse (bottom) and varistor (top, blue). If the fuse has blown, you should also change the varistor.
