Hi guys, like the title says, my AC200Max has 4220v 20A sockets and 1120v 30A… I would like to use the 30A socket to plug to our generator in but our house runs 220v Line-to-Line. Im really confused why its like this, is there a way to convert this 120v to 220v socket? and will it retain 30A?
This seems a bit odd to me. What country version of the AC200Max do you have (could you include a picture of the front of yours)?
It is my understanding (I’m quite willing to be corrected) that the 240 volt versions only include 240 volts, and no 120 volt output, since the inverter only outputs 240 volts. I’m not sure how you could have both in your device? Have you measured the output voltage from the sockets?
there was a mistype on the phil website showing both 240 and 120 i ha e emailed them and they have updated the website…
i also checked with a multi meter its all 220-240v thanks
I’m glad to hear there was just a point of confusion. So, will you be able to run some part of your house through your generator connection then?
